Network Management
Contributor II
Airwave and LDAP
Two questions about getting Airwwave and LDAP to function.
1.  Is the "description" the only LADP attrbute that can be used?
2.  I have a master and 3 managed AMP's, is there a way to export from the master and then import the roles and LDAP rules to to the managed amp's?
Brian Warren
Re: Airwave and LDAP
Correct, we only use the description field in LDAP.
And that's a great feature request.  We currently don't do export/import of user roles in AMP.  At this time, you'll have to create the roles manually across each AMP.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
