Network Management
Airwave auto discover for Aruba switches
We have instaled AirWave 8.2.1.6 recently and trying to auto discover the Aruba switches but not happening.
We can add manually the same Aruba switch successfully.
The switch model is Aruba 2530 24G POE+.
In AMP device setup--> communications page we have configured SNMP parameters and also the same parameters in Aruba switche as well.
Can any one help please...
Ashok
Moderator
Re: Airwave auto discover for Aruba switches
Did you also set up / configure the discovery scan?  This is done on the Device Setup -> Discovery Scan page.  You add a network, then add scan creds, and then add scan set (combo of the networks and creds to use in the network scan).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Ashok,
You have to add new scan set for switch to auto discover in DeviceSetup>Discover page
Pavan
If my post address your queries, give kudos and accept as solution!
Sorry for the late response.
I have opned a TAC with Aruba and have come to know that the Auto discovery will work only when the device management interfaces are in VLAN 1 which is default.
TAC asked us to add all the devices manually.
Thanks and regards,
Ashok Kumar Sunkara.
well that is disappointing, i was trying to do the exact same thing as you were!  Thanks for posting the result so i can stop trying to do it.
