Network Management
Airwave can't add Aruba 2530 switches
Hi I have recently got some Aruba 2530 switches with the latest firmware on. On the switch I can add the Airwave settings to add the device to Airwave.
On the Airwave I can see the folder I have added from the switch but the switch it self I can not see.
Re: Airwave can't add Aruba 2530 switches
We need to provide switch details in Airwave to add the device. Naviaget to Device Setup > Add  page and click add to manually add the device.
Note: Make sure configure snmp community string in swtich before adding the swtich to airwave.We need to proivde IP addresss, telnet/ssh and community details.
Pavan
If my post addresses your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor I
Hi Pavan,
Do you have any reference on how to do the config, via cli or web
Regards.
