Network Management
Super Contributor II
Airwave clustering
Hi!
Last Airheads there was alot of talk about the Airwave clustering feature coming up in 8.x. Does anyone have any news on when to expect this feature? Will it be possible to upgrade an existing Airwave deployment to form a cluster over several nodes?
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Re: Airwave clustering
AirWave 8.1 will feature clustering and it is still on target for early 2015.
Tim Cappalli | Aruba Security
Any ideas or information on how it will be to implement the clustering? I´m wondering if it will be just to add machines and configure clustering or if it´ll need a total fresh install.
You will be able to migrate data but you still have to add additional servers.
Keep in mind that clustering is designed for very large environments (5000+) devices or high levels of redundancy. A minimum of 4 servers will be required (2 database, 2 "workers").
There will be more information as the release date gets closer.
Contributor I
Will AirWave also feature license sharing?
elmodoeswifi,
When you say license sharing, what do you mean?
Is there any different hardware requirements for 8.1?  I am in the process of working with vendors right now on configuring servers to replace my aging infrastructure.  Any advice?
Please reach out to your local Aruba team for more details.
Mr Cappalli,
I know this is an old post but is there any update on when Airwave 8.1 will be out?
Thank you.
apasquali wrote:
Mr Cappalli,
Thank you.
This has not been determined.  Is there a fix/feature that you are looking for?
