I have setup a monthly cronjob on Airwave that keeps disappearing.
Initially I add it in with 'crontab -e'. After it lists fine with 'crontab -l', but then a day or two later it is no longer listed when I run a 'crontab -l'. The script itself is located in /var/airwave/custom.
The job is set to run on the first day of every month. Initially I had it set to run every week, which was fine, but then it was changed to be every month, and now it keeps disappearing.
Anyone else seen similar behaviour or set this sort of thing up on Airwave?
