Network Management
Airwave dmidecode offline installation
Hi Community,
I usually do dmidecode to get the airwave (out-of-the-box 7.5.x version) sytem information but after upgrading to 7.7.x this tool does not work. I guess it needs to be installed separately. Is there a way to install dmidecode offline?
Oliver
Moderator
Re: Airwave dmidecode offline installation
To install offline, you need to download and SCP the RPM file into AirWave:
filename = dmidecode-2.12-5.el6_5.x86_64
((http://mirror.centos.org/centos/6/updates/x86_64/Packages/dmidecode-2.12-5.el6_5.x86_64.rpm))
transfer this into /var/airwave/custom
then install:
# rpm -i dmidecode-2.12-5.el6_5.x86_64
After that, you should be able to run the regular command:
dmidecode -s system-serial-number
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
