Network Management
Airwave external syslog no audit information only system?
I have finally gotten around to send syslogs from AIrwave to an external syslog server but what I am not seeing is the audit logs.
So what I see on my syslog is the following:
Jan 22 00:38:46 AMP (wips-aw-1)[29819]: Aruba Instant Virtual Controller CAT-GA-ATL-01555-VC1 Up#011System#011Device#011ID: 398#011Top > CAT - Atlantic Trust > CAT-GA-ATL-01555#011CAT-GA-ATL-01555
Jan 22 00:43:33 AMP (wips-aw-1)[24886]: Universal Network Device CAT-GA-ATL-01555-SW1 Configuration verification succeeded; configuration is good#011System#011Device#011ID: 401#011Top > CAT - Atlantic Trust > CAT-GA-ATL-01555#011CAT-GA-ATL-01555
But what I don't see is user actions that are recorded in the event log on AMP, they do not appear in the syslog. Example:
Wed Jan 22 08:30:45 2014     dmcmonitoring     System     Alert 'Device Down Device Type is Remote AP or Minutes Down Threshold >= 5 minutes for CIB-ON-MIS-04922-WAP1' acknowledged
Wed Jan 22 08:30:45 2014     dmcmonitoring     System     Alert 'Device Down Device Type is Remote AP or Minutes Down Threshold >= 5 minutes for CIB-ON-MIS-05432-WAP1' acknowledged
It seems to only gather syslog information coming from System but not users performing actions on AMP.
My syslog is configured as such...
EDIT: also it seems as though not all messages are being captured...seems a bit slow.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Airwave external syslog no audit information only system?
Anyone?
ACDX #420 | ACCA
TAC confirmed this is not possible currently within AMP.
ACDX #420 | ACCA
Frequent Contributor II
Does anyone know if this is possible now?
Rosie,
We have user option in Audit trail drop down list, could you choose that option and click, send test message and check whether you are receivng Airwave user related events.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Does this send GUI audit logs?
Its should send the the entries of changes made by GUI user but I am not 100% sure, try set it to audit and send test message and check the status.
Pavan
Pavan
I see audit logs but I am not seeing logins from the GUI.
Syslog is also being bombarded by the following:
 session opened for user igc by (uid=0)
