Network Management
Frequent Contributor I
Airwave for supervising Clearpass
Hi Folks,
I can not configure my Airwave for supervising my Clearpass in SNMP V3.
I have returned all parameters in Airwave and Clearpass for SNMP v3 but all the time the airwave said “the device is currently using SNMP version 2c”
I use this Version
Airwave v7.7.7
Clearpass 6.2.3
Re: Airwave for supervising Clearpass
In the Airwave Group that the device is in, you can specify which version of SNMP is used to manage that device.
Hi Cjoseph, unfortunately, i had already configure the group before add the clearpass device (see attachments). Regards Yann
Moderator
-updated-
We're seeing the same behavior, this has been filed as DE16912
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
