Network Management
Frequent Contributor I
Airwave (iso) from USB Stick installation
i have a server hardware and i want to run Airwave natively on it for a test. After i get a usb stick running i ran into the error that the default start search for a ks.cfg file on the cdrom:/ after i change it to the usb stick hd:sdb1:/ks.cfg (in my case) it found the config. Then i choose the keyboard and after that the setup says no driver found ?! select a driver or use a driver disk. But driver what for ? And where ?
Any suggestions ?
Airwave 8.2.2.1
Thanks in advance
ACMP
