Network Management
Frequent Contributor I
Airwave keeps complaining about configure mis-match for a Virtual Controller cluster.
I have a 3-IAP (2-IAP215 with 1-IAP109) cluster managed on Airwave (v8.0.6.3). Periodically, Airwave will complain of mismatch for the cluster, like below. (I normally just click Repair to kick it away but several times a day is really annoying)
However I do not see any mismatch configuration under Instant Config-> AirWave->Mismatches.
If I go to Instant Config-> AirWave->Config History, I can see following.
So now, I would like to understand more about why it keeps complaining? Should I turn on auto-repair mode? If so, how to modify the group to do so?
/S
Re: Airwave keeps complaining about configure mis-match for a Virtual Controller cluster.
Please check Rapids Containment Options->if enabled Manage rogue AP containment? if yes, that is reason why airwave->monitor page display mismatch but can't find any thing in IGC->mismatch. dev is coding to fix this, aims to fix this in future release 8.0.7.
That is the case for my setup.
Do you have an ETA for the fix?
