Network Management
Frequent Contributor I
Airwave licensing
Hi Airheads,
While I understand that the LIC-ENT license provides a LIC-AW license to manage an AP, and an extra LIC-AW can be purchased to manage a controller - what about ClearPass servers and RAPs that are managed by Airwave?
Do these also require a LIC-AW to manage?
Re: Airwave licensing
any device on Airwave consumes 1 x LIC-AW.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Trusted Contributor I
i might have missed something but you don't manage Clearpass from Airwave right? RAPs are just the same as normal APs and controllers, they do require a device license.
Hello, Can you please help me in the airwave licensing part.
I have a project for a school so I have to choose between the airwave license (with visual RF and RAPIDS JW546AAE) and the k-12 licenses (JW605AAE and JW467AAE).
Can you state the differences between both and if the K-12 licenses have the same features as the JW546AAE)?
Please check below community link, which provide in detail
https://community.arubanetworks.com/t5/Technology-Blog/My-Networking-Portal-Licenses/ba-p/284961
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
