Network Management
lsk
Occasional Contributor I
Airwave lost connection constantly
This might not be an airwave issue. My airwave is installed in SAN storage and running through hyper-v. It will lost network connection every now and then and i will need to reboot the airwave server for it to come back. This issue had been bothering me some time.
Re: Airwave lost connection constantly
Do you have AirWave support? You may want to open a TAC case. They can go through the logs and try to identify the problem.
Tim Cappalli | Aruba Security
lsk
unfortunately, mine's expired
Do you mean it is losing connection between your browser and Airwave, or Airwave and the controller?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
lsk
airwave itself lose connection to network
How can we troubleshoot if this is a problem with your infrastructure?
Aruba TAC should be able to help you.. however I read that your support has expired.
The following may help you to find a solution.
If you search on the internet, there are numerous issues with RedHat EL/CentOS on Hyper-V and losing network connectivity under load. You may work with Microsoft support to get these issues fixed.
What may help, is changing the network adapter in Hyper-V to 'legacy'; that solved the issues in few cases. Please also look throught the following Knowledgebase article: http://community.arubanetworks.com/t5/Monitoring-Management-Location/How-to-Install-Airwave-on-Hyper-V/ta-p/182990
Changing the network adapter it to another option and see if that works better for you may help as well..
Herman
Contributor II
In case anyone else runs into this on a Hyper-V 2012 R2 setup:
I have a 2012 R2 Hyper-V Cluster and the only server I had dropping network connection constantly (usually ever 20 hours or so) was AirWave 8.0.5 (initially).
I tried installing Linux Integration Services Version 3.5 tools for Hyper-V (I had to remove 3.4 for it to install clean).  I upgraded to 8.0.7.  I rolled back any of the nfs mounts I had been using for backups - but I kept losing network.
Then I actually removed the 'legacy' adapter and gave it a standard network adapter.  I had to edit ifup files for eth2 instead of eth0, but then the network stayed up.  The only piece that didn't work was authentication through Clearpass.  I needed TAC for that; essentially the AMP database needed eth0 updated as well.
Airwave has been up for weeks now and oddly enough the fix for me was to get off the legacy adapter.
Hi Everyone,
I know this thread is old however this bug still exists within the AirWave OVA. I resolved the same issue your dealing with and I documented it via the link below. It had to do with a CentOS irqbalance issue when you assign multiple vCPUs to the AirWave VM. This issue is in fact due to a RedHat bug that is documented within my research.
https://www.slideshare.net/TravisKench/aruba-airwave-connectivity-issues-on-hyperv-93713395
Please let me know if this resolves anyone else's issues.
Travis
Travis
