Network Management
Airwave management authentication using radius server
Hi Everyone,
I have a query regarding the management authentication for the administrator for Airwave using windows Radius server.
We have configured the NPS (win 2008) server and also configured the Radius server on the airwave by navigating to AMP setup - > Authentication.
Authentication is working fine using PAP but we require the authentication to use MSCHAPv2.
Do we have to enable on the Airwave in order to the Airwave to use the MSCHAPv2 as a authentication protocol for authenticating the management users instead of PAP?
Thanks in advance.
Re: Airwave management authentication using radius server
I don't believe this is supported...
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Hi SethFiermonti,
Thank you for your reply.
So you mean we cannot use MSCHAPv2 or any other authentication protocol for authenticating Airwave management access if we use Radius server? So only PAP is used between the Airwave and Radius server for authenticating?
Do we have this feature in future relase?
Thanks again.
I made an RFE in the ideas portal.
Promote it if you'd like
https://arubanetworkskb.secure.force.com/prm/ideas/viewIdea.apexp?id=08740000000LFFH
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
This works from 8.2.3 version of Airwave.
https://community.arubanetworks.com/t5/Monitoring-Management-Location/Is-PEAP-MSCHAPv2-is-support-in-AMP-for-radius-authentication/ta-p/290995
Vishnu
If my post helped you, don't forget to give kudos ;)
