Network Management
Airwave manages Cisco Nexus?
Hi Team
I´m a rookie in Aruba world and right now makes the introduction.
I have a particular -and interesting- question about Aruba Airwave and Cisco Nexus product....Is it possible the management of the nexus devices and whats the level of management with Airwave platform?
Best Regards
Re: Airwave manages Cisco Nexus?
No special support was added.  You can try adding as Cisco Catalyst Switch or generic Router/Switch.  If it's using the same MIBs as the catalyst line, then it should work.  Otherwise a feature request would need to be filed to add support into a future release.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
