Network Management
Airwave monitoring ClearPass -> Down
Hi folks,
fresh installation of customer consists of Airwave version 8.2.5.1  and ClearPass 6.7.0.101814. We successfully added mulptile different device types to Airwave for monitoring. But when i add ClearPass, it shown UP for ~5 minutes and than it turns to DOWN. Double checked community string and SNMP version. Airwave and ClearPass Data/External port are on the same subnet (ClearPass Monitoring port is not reachable for Airwave)
Alerts/Events for ClearPass:
TIME USER EVENT
Thu Jan 18 13:17:29 2018 System Status changed to 'SNMP get failed'
Thu Jan 18 13:17:29 2018 System Down
Thu Jan 18 13:12:29 2018 System Error in SNMP polling: Timeout(interface_error_counter)
Thu Jan 18 13:12:29 2018 System Error in SNMP polling: Timeout(interface_monitor)
Thu Jan 18 13:12:29 2018 System Error in SNMP polling: Timeout(device_resources)
Thu Jan 18 13:12:29 2018 System Error in SNMP polling: Timeout(interface_bandwidth)
Thu Jan 18 13:11:29 2018 System Status changed to 'OK'
Thu Jan 18 13:11:29 2018 System Up
Thu Jan 18 13:11:29 2018 System Firmware changed to '6.7.0.101814'.
Thu Jan 18 13:11:26 2018 admin Configuration change submitted
Thu Jan 18 13:11:26 2018 admin Authorized
Thu Jan 18 13:11:26 2018 admin Created
Moderator
Re: Airwave monitoring ClearPass -> Down
Did you add the CPPM server in as CPPM, Aruba Device, or Universal Network Device?  I'll have to try this out in the lab when I get a chance, but might find faster resolution by opening a TAC case.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
This might be related to ClearPass issue #43392, which describes a stop of the SNMP service in ClearPass 6.7.0 when specific counters are queried by Airwave.
I would advise you to open a TAC case on ClearPass to verify if that is the issue.
