Network Management
Airwave monitoring client's bandwidth usage
Hi community,
i'm trying to use Airwave 8.2.3.1 to monitoring a network, based on IAP and hp switches, all added and installed.
The goal is to know when a client and which cilent is saturating/using too much network, but i can see only AP's usage not clients.
I'll need it on real time so... no reports.
There is a function that i missed? Or have any ideas?
If i can ask a second thing, i have switches which have lan clients, i can see "neighbors" and "connected devices" correctly, but can't see any client.
Re: Airwave monitoring client's bandwidth usage
We could either create a custom view in clients>connected page to see the client usage section or set a client usage trigger from system>trigger page.
Regarding HP switch clients not showing in Airwave , may i now the model/firmware version?
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
on clients>connected is very useful, i searched it on "All" and there isn't a "usage" section, but can't be sort for usage? I can use a trigget to alert then going to "connected" and see who, but if i can sort for usage will be more easy to view.
Switches are:
HP J8770A 4204vl
HP J9022A 2810-48g
HP J9028B v1800-24g
HP J9776A 2530-24g
HP J9728A 2920-48g
HP J9853A 2530-48g
firmware is the latest updated on april (i can't reach them in this moment for write the exact name).
It is avaiable in client>connected pag, click on Arrow, it will ist New View option , click on this to create custom view.
Attached latest support device, guide, it looks we does not have complete support for the listed version.
Pavan
Pavan
What i meant is that i can't sort/order the view based on usage, but i use a trigger to alert when a client go over a certain usage.
Ok then i can't see lan client because switches aren't supported.
Thanks for help
For switches there is something to do?
Cause my customer want a total control, if Airwave can't control lan clients he'll leave this project.
Portal for request a features redirect to HPE, and is now available at the moment.
edit: i have to open another topic or i can use this?
I would recommand to file feature request and follow up with your accounts team for update.
If you have any different queries, please open new topic.
Pavan
Pavan
HI,
Sorry I have to reply to this post because:
1. Can you provide a direction for us to create new POST/Questions?
Hi Borely,
starting from the home page of community, click here;
go to discuss, then select a category and now you'll see a "Start a topic" orange button.
