Network Management
Frequent Contributor I
Airwave not showing SNR under RF Performance Charts
I am trying to figure out why Airwave is not showing the SNR info under RF Performance.  Health and Speed are shown but SNR is not.
I am using the default-amp profile on all Aruba controllers (ArubaOS 6.4.0.1) and Airwave 8.0.1.
Any suggestions as to where to look for troubleshooting?
Thanks!
Re: Airwave not showing SNR under RF Performance Charts
Is amon enabled under AMP Setup -> General ?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
Do you have AMON enabled ? on both sides?
Thank you
Victor Fabian
Lead Mobility Architect
AMON is enabled in Airwave.  I have also setup Airwave as the mgmt-server on the controllers using the default-amp profile.
OK, I changed "Prefer AMON vs SNMP Polling" from Yes to No, and now I am getting the SNR info.  Not sure why that fixes things...
There is no firewall stopping UDP 8211 traffic between Airwave and the controllers.  I am not sure what else would be stopping AMON from working correctly.
Are you allowing 8211/UDP between controller and airwave ?
Also checked if the information is getting send out:
show mgmt-server message-counters process wms
show mgmt-server message-counters process stm
Thank you
Victor Fabian
I have confirmed there is no firewall stopping PAPI traffic.
I did check the mgmt-server counters before and they showed messages being passed as I would expect.
Going to try upgrading AMP to the latest version and see if it makes a difference.
That was going to be my next suggestion..
Theres been a lot of bug fixes since 8.0.1
Thank you
Victor Fabian
you shouldn't have to do prefer AMON vs SNMP to make it work.
As victor suggests, upgrade is your best course. I would then test without that option enabled and see if you are getting SNR results
ACDX #420 | ACMP
Upgrading to AMP 8.0.5 appears to have resolved the issue.
Thanks for your help!
