Network Management
Regular Contributor I
Airwave seems not install on a cluster
HI,
i have an airwave that manage 10 cluster of IAP.
For some reason on one IAP' s Cluster the configuration still remains in pending.
thi issue is blocking the deploy of configuration.
By ssh on IAP i see that configuration is pushed.
Can you help me to understand how i can fix it?
There is some command that i can use to force the stop of push configuration?
Regards
Andrea
