Network Management
MVP
Airwave - show mesh portal/point/status
We have a wired AP which apparently doesn't like the wire very much. It pulls power from it, then can't bring up ethernet so it connects to neighboring APs as a mesh point. That's cool, but not what we want.
I figured that I should be able to find the mesh status of an AP in Airwave, but I'm not seeing it.
I was able to query the database and get the list of errent mesh-points (mesh mode 2) - just the one.
Now I want Airwave to track and send an alert if the mesh mode/status changes for an AP.
Can someone show me where to look for that?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
