Network Management
Airwave showing Aruba WAPs as rogues
My Airwave 8.2.6.1 is showing aruba WAPs as rogues. Has anybody found a solution for this? Also does anybody know if there is a way to derive the wired MAC for a WAP from the radio MAC?
Frequent Contributor I
Re: Airwave showing Aruba WAPs as rogues
Aruba the Aruba AP's that are being detected as Rouge managed by you? i.e. are they in AirWave as a managed device?
ACCP ACMP CWDP CWSP
