Hi All,
Im currently finding a solution for the following
I've got a Airwave server and this server is used to configure IAP-225 accesspoints at remote offices. This configuration is done by Groups, where every office has its own group.
Now, some of these offices are placed in busy malls and show more than 50 rogue SSID, which course blurs my view. So i did the following:
"Ignore Rogues Discovered by Remote APs" = "Yes" under the basic configuration of specific groups. But unfortunately i still see the 'suspected rogues' under the Rogue tab.
So i also changed the following setting under 'RAPIDS > Setup'
Ignore Rogues Discovered by Remote APs:
Discovery events from WMS Offload will always be processed, regardless of this setting.
Still i see the rogues of all the IAP accesspoints.
Am i missing something here?
