Network Management
Occasional Contributor I
Airwave solutions
Multivendor switch can manage through the airwave?Let say example Juniper, Cisco,HP etc
Re: Airwave solutions
Please refer to the AirWave 7.7 Supported Infrastructure Devices document that can be downloaded as part of the Airwave documentation (
That document lists supported switches, controllers, APs for AirWave.
