Network Management
Contributor I
Airwave ssid report
Can anyone tell me if there is a way to configure a report in Airwave that will show all AP's broadcasting a certain SSID?
I have tried but cannot seem to find the right way to do it.
Re: Airwave ssid report
Why don't you do this on the commandline of the controller - "show ap bss-table | include <name of ssid>"
Contributor I
I will need to run that on each controller and as we have 14 controllers it wil be a very manual process, show bss-table will also show both radios and I just need to know about the SSID
I need to know how many and which AP's are broadcasting each SSID as it will be a charging model to customers
Device Summary Report and choose Devices.  The you can filter on the particular ssid.
ACCP, ACCX #817, ACMP, ACMX #294
Contributor I
Hi Michael,
Yes I have tried this already but it gives incorrect information. It seems to list all AP's that can 'hear' the SSID. I did this for one SSID and there were some airmonitors in the list. I also ran it for an SSID that I know is only on 2 AP's and it returned 25 devices
Try the on_controllers command on the Airwave CLI.  Your can filter on the ssid and save the output to a file which you can import into excel and play around with.  If all your APs are 802.11n, then filter on a-HT as well to only show the 5GHz radios.
on_controllers "show ap bss-table essid <name> | in a-HT" > essid.txt
