Network Management
Airwave supported Products details
Dear Support,
Need information about the below products which is supported by Aruba Airwave.
Information about MIB-I and MIB-II
1) Ruckus ZoneDirector
2) R700 Aps
3) Fortigate firewall/controller
Aps – 320B
- 221B
- 320C
- 222B
4) Extreme – X460
- X440
- X670
- X430
5) Cisco – SG300
- 2960X
Re: Airwave supported Products details
Attached is a list of supported devices within AirWave. While these devices can likely be added as 'Generic Network Devices', that granularity falls mostly to up/down monitoring only. Otherwise, they are not supported for any advanced monitoring that supported devices will have.
Jerrod Howard
