Network Management
Airwave upgrade
What is command to upgrade to AMP 8.0.4?
Re: Airwave upgrade
on the commandline, type "start_amp_upgrade -v 8.0.4"
Re: Airwave upgrade
How do you do an offline upgrade? I have the file on the root.
Sent from my iPad
Re: Airwave upgrade
Same command. The offline upgrade requires the .tar.gz file at the root, NOT the Iso or the VMware image.
Re: Airwave upgrade
I am going to upgrade also but have a new physical server arriving any day now. What steps are recommended in backing up my current server, then restoring to the new box?
Re: Airwave upgrade
Please see the instructions here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/Migrate-Existing-AMP-Installation-To-A-New-AMP-Server
Re: Airwave upgrade
Thanks!!
