Network Management
MVP
Airwave uprade to 8.0.0 -- VisualRF issues
It's great that flash if gone, my boss likes looking at floorplans on his iPad.
We notice however that the heatmaps got a LOT cooler in the new version (poorer coverage, not The Fonz)
We've been using VisualRF to plan a new store deployment and have been hitting the mark pretty squarely each time. The store which we were finalizing yesterday now looks terrible.
I can't find any assumptions or settings in the system which were changed, but predicted coverage dropped terribly.
What's changed? and how do I change it back?
Plan yesterday afternoon (flash-app):
Plan this morning (html5-app):
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Re: Airwave uprade to 8.0.0 -- VisualRF issues
Msabin,
Is this pre-deployment?  Please screenshot your settings on both.
Trusted Contributor I
Have you tried measuring the floor again?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
MVP
This floorplan is all planned APs in pre-deployment planning.
I re-measured the floorplan which changed nothing.
Here are the floor and AP properties we use for our planning, I can't show the former screenshots since we've upgraded and can't go back easily, but they are the same assumptions we've used for 60 or so stores.
--Matthew
MVP
I have further tried restarting VisualRF and switching back to flash.
Now live floorplans looks pretty similar to prior, but planned floorplans still look terrible (in both html5 and flash)
I've got a ticket open with TAC, unless anyone has any more ideas, I'll just wait on TAC and report back what I learn.
--Matthew
Occasional Contributor I
I just upgraded from 7.7.11 to 8.0.0 and I'm seeing the same issue.   DWG imports don't load a floor plan in HTML5 mode and in Flash no layers are showing up to unselect unneeded layers from our facilities master floor plan files.
Seems as though I am suffering from the "cooling" issue as well.
I'll dig deeper into this and see if I can find anything.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
MVP
TAC has been able to reproduce the problem, and is processing it as a bug.
I'll keep you posted as the ticket proceeds...
--Matthew
amazing.
if you get BUG ID, can you share so if I open a case ill refer to it to get more eyes on it.
ACDX #420 | ACCA
Frequent Contributor I
Ditto, I am experiencing the same issue, so i will call in and let them know more people are seeing the problem if you can get an bug ID.   So far i am liking 8.0, just got to get things fixed.
