Network Management
Contributor II
Airwave
Can you upgrade the vmware tools installed on Airwave. I am runnning vmware tools version 7 and i want to go with version 10. I read that is not recommended for ClearPass, Does anyone know if the upgrade will cause Airwave to fail?
Re: Airwave
You should be fine with Airwave, upgrading the VMWARE tools.
