Network Management
Re: Airwave
Thank you for your advice.
The default boot option of  the server is UEFI for this hardware, but we have changed it to Legacy BIOS but still the issue is same with both 8.2.6.1 and 8.2.5.
Thanks and regards,
Ashok Kumar
Moderator
Re: Airwave
Scratch that - found it earlier in the thread - checking with the support team.
So we're sort of on the right track, unfortunately - I don't have that server model in the lab to test against.  Can you send me the case number you have open with support?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Moderator
Re: Airwave
Checked with support and they said the case was closed, did the install work?
Rob Gin
Re: Airwave
Thanks a lot for your help.
First we have installed the CentOS6.9 as suggested by the TAC engineer and then connected the system to the Internet and have given remote (SSH) to TAC engineer.
He installed the same ISO 8.2.6.1 AMP version on top of CentOS and now my application is successfully installed and working fine.
Thnaks,
Ashok Kumar S.
Moderator
Re: Airwave
Thanks for the update!
Rob Gin
