Network Management
Trusted Contributor I
Airwaves Upgrade
Two questions:
How do I determine if my current Airwaves install is 32 or 64 bit?
I need to upgrade from 7.2.5 to 7.5.5.  Can this be done in one upgrade or do I need to do it incrementally starting with update 7.3.8 and so on?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
MVP
Re: Airwaves Upgrade
The Airwave 7.5 Announcment page (here) has a "path to 7.5" link (here)
You should probably go to 7.3 or 7.4 on the was to 7.5.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
You can tell on the command line whether it's 32- or 64-bit with the "uname -a" command. If the response includes "x86_64", then it's 64-bit; if not, then it's 32-bit.
