Network Management
Alert keeps appearing in AirWave
Hi guys,
There is an alert that keeps appearing in AirWave which is
Do you know what does it mean?
I have acknowledged it but appears again and again. What can I do?
Julián
Re: Alert keeps appearing in AirWave
Hi Julian,
List of traps
https://community.arubanetworks.com/t5/AirWave-and-Network-Management/SNMP-Trap-Filter/td-p/12333
MIB guide
https://community.arubanetworks.com/aruba/attachments/aruba/IAP/1529/1/Aruba%20Instant%206.2.0.0-3.2%20MIB%20Reference%20Guide.pdf
WLSX-TRAP-MIB::wlsxColdStart
wlsxColdStart NOTIFICATION-TYPE
  -- FROM       WLSX-TRAP-MIB
  OBJECTS       { wlsxTrapTime }
  DESCRIPTION   "
            An enterprise version of cold start trap, which contains the controller time stamp.
                "::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) aruba(14823) ar        ubaEnterpriseMibModules(2) arubaAp(3) wlsrEnterpriseMibModules(1) wlsrTrapMIB(11        ) wlsxTrapsGroup(1) wlsxTrapDefinitionsGroup(2) 1111 }
Pavan
If my post addresses your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
Thanks for your response.
1. But what does the trap cold start trap mean?
2. And why do I get this trap? I configured nothing related to SNMP in my Instant cluster and as far as I know the communication between AirWave and Instant is over HTTPS.
Julián
Julian,
 IAP also have list of traps but we can not disable manually unwanted traps in IAPs. I have shared IAP MIB guid which provide complete trap details.
Trap is related to your IAP time, since you have configured trigger condition in Airwave's system>triggers page, may be there is change in time because of that Airwave triggered alert.
 IAP sends traps using https protocol only.
Pavan
Pavan
Hi Pavan,
I have checked the IAP MIB guide you shared but the only thing it says is
Then I have looked for cold start trap, but it doesn't explain nothing about this. I think is because the Instant has restarted, but I wanted to confirm.
Thanks anyway, because now I can disable this Alert under Airwave System > Triggers.
Julián
