Network Management
Aligning floorplans in Airwave
I am setting up a site in Airwave 8.  I am trying to align the floorplans so that Airwave knows what is directly above what.
I understand that you need to put a checkmark next to "Origin" under "Foorplan Features" when viewing the floor.  A crosshair icon appears in the upper left corner of the floorplan.  I understand that you align the floorplans by dragging this origin crosshair icon to a common point on the floorplan.
The problem is that it just wont move - I cant grab the icon.
Is there something that I am missing?
Re: Aligning floorplans in Airwave
Is the floorplan unlocked?
Tim Cappalli | Aruba Security
MVP
That bites me more often than I should probably be admitting... ;)
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Well duh.  Thanks for that!  All the best.
