Network Management
Contributor I
Re: Analytics & Location Engine: how upload SSL Certificate?
No, the certificate in ale.domain.com.crt is different then certificate on top of the 3 in the ca-bundle...
May be you have two intermediate CAs and one root CA in bundle. Copy the server certificte first and remaning three next in line in notepad ++ and save it in .pem format and upload.
If that not fix the issue, please open TAC ticket.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor I
Yes we have two intermediate certificates in it..
Are you able to upload now?
Pavan
Pavan
Contributor I
It is working now. Thanks for the help!
Good to hear, that finally issue got fixed.
Pavan
If my post address your query, give kudos:)
Pavan
