Network Management
AppRF data missing from local controller AP's.
We have master/local setup and we decided to move all of our AP's to local (aruba recommended). Ever since we made the move, none of the AppRF data (only see mininmal lldp/udp traffic)  shows up on the on AirWave. We have AppRF enabled on both controllers and has only worked on the master prior to merging all AP's to the local. Is there something I'm missing on the AirWave or the local controller to get the AppRF to display on AirWave.
AirWave AppRF view for all clients:
Re: AppRF data missing from local controller AP's.
Do you have amon enabled on the local controller?
Sent from Nine
Tim Cappalli | Aruba Security
Looks like it's not enabled on the local and AMON vs SNMP polling is disabled, not sure if these option matters.
The airwave option does not matter.
Not having it enabled on the local controller matters.
