Network Management
AppRF data not showing up
Is there anything special I need to do to enable AppRF data display?
I'm not seeing any data.
Using 7005 controller on 6.4.3.7, Airwave 8.2.0.2, Campus AP's (205, 215).
Thanks!
Re: AppRF data not showing up
Did you run the mgmt-server command to enable AMON?
Are you seeing the AppRF data on the controller?
Tim Cappalli | Aruba Security
Maybe a really stupid question, but does your controller show AppRF data?? It should be visible in the controller dashboard before it can be sent to Airwave. And then, yes you need to configure AMON between controller and Airwave to pass on the AppRF data.
Not a stupid question... the problem was the controller config.
Thanks.
On a related note, web reputation data is not showing up.
I've typed 'firewall web-cc'
Is there anything else I need to configure?
Thanks!
Pretty sure you need to have firewall-dpi on for that as well.. Relevant items from my controller:
firewall dpi
firewall web-cc
firewall-visibility
Speaking about web reputation, be aware that this feature may require a subscription to the reputation database in the future, like it does in Aruba Instant. Contact your partner or local sales team for more information.
I've got all those statements in my config, and I've done a reboot.
Still no web reputation data.
Any other ideas?
Thanks.
Does your controller have outbound access to the internet?
Yes, I can ping 4.2.2.2 from the controller gui.
Is there anything else that needs to be enabled?
Thanks.
Make sure you have DNS configured on the controller and the controller can connect to the cloud web classification service (HTTPS, port 443 in my lab).
Without DNS, the contoller cannot find the correct cloud services.
Yes, of course.
Name resolution is a good thing.
That did it!
Thanks for all your help.
