Network Management
Aruba 225 VC and using Aruba Central
We have 10 IAP-225s run by the virtual controller.  I want to connect them to Aruba Central.  I have added the devices in the device inventory and they are subscribed but it does not look like they connected and no data is showing up.  Neither device is the Master VC.  I have run the command show ap debug cloud-server which outputs
IAP mgmt mode              :local-mgmt
cloud config recved        :FALSE
state diff                 :disable
Device Cert status         :SUCCESS
Do I have to add the VC to the device list or do I have to break up VC and manage them through Aruba Central?  I would like to use Central for visability not really management.  Thanks for any info on this.
