Network Management
Aruba AP 105 Reboot Loop
Community,
I have attached a brand new 105 AP to the network and get the following:
APBoot 1.2.4.4 (build 26618)
Built: 2011-01-07 at 13:42:04
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: 128 MB
POST1: passed
Copy: done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 100 Mb/s full duplex
DHCP broadcast 1
DHCP IP address: 10.129.129.8
DHCP subnet mask: 255.255.255.224
DHCP def gateway: 10.129.129.1
DHCP DNS server: 0.0.0.0
DHCP DNS domain:
Controller address: 10.129.129.166
Using eth0 device
TFTP from server 10.129.129.166; our IP address is 10.129.129.8; sending through gateway 10.129.129.1
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: ICMP Host Redirect to
*** Reboot caused by watchdog timeout. ***
The AP is stuck in a reboot loop. It obviously sees the controller and get an IP but it never binds to the controller. Controller is a 3200XM running 6.4.4.11 code. Any ideas? I read a few similar articles on here, one of which said to RMA the AP.
Thanks.
Re: Aruba AP 105 Reboot Loop
Statically configure the ip, subnet mask, default gateway and "masterip", and see if it still happens.
Long story short, APBoot 1.2.4.4 cannot handle ICMP redirects without crashing.  Later revisions of the AP-105 hardware APboot have this patched.  The only workaround is to avoid ICMP redirects, by statically configuring the parameters.
