Network Management
Aruba Airwave AppRF
  • 1.  Aruba Airwave AppRF
    Posted Oct 01, 2014 01:33 PM
    Why do i only have the ports listed in the applications in airwave?  The controllers resolve the port to an app
    ie - facebook on the controller is a port number on airwave.
  • 2.  RE: Aruba Airwave AppRF
    Posted Oct 01, 2014 08:13 PM
    Do you have a DNS server defined in Airwave?  You also need AMON configured on the controller to point to Airwave.
  • 3.  RE: Aruba Airwave AppRF
    Posted Oct 02, 2014 08:45 AM
    yes i have dns on airwave and the amon pointing to airwave from the controllers.  the firewall stats on the controllers shows all the apps and destinations correctly.  something is missing...help!!
    show mgmt-server pro
    Mgmt Config profile List
    Name         References  Profile Status
    default-ale  0           Predefined (editable)
    default-amp  0           Predefined (editable)
    Total:2
    (xxx-LOCAL) #show mgmt-servers
    List of Management Servers
    Type     Primary Server  Profile
    AirWave  xxx.xx.xx.xx    default-amp
    Num Rows:1
    (xxx-LOCAL) #show mgmt-server profile default-amp
    Mgmt Config profile "default-amp" (Predefined (editable))
    Parameter        Value
    Stats            Enabled
    Tag              Enabled
    Sessions         Enabled
    Monitored Info   Disabled
    Monitored Stats  Disabled
    Misc             Enabled
    Location         Enabled
    Voice Info       Disabled
    [root@airwave mercury]# cat /etc/resolv.conf
    nameserver xxx.xxx.xxx.xxx
    nameserver xxx.xx.xx.xxx
  • 4.  RE: Aruba Airwave AppRF
    Posted Nov 06, 2014 01:10 PM
    What AirWave version?  What AOS firmware version?
    Make sure that you have valid credentials to Telnet/SSH to controller from AirWave.  For AMON consumption, valid Telnet/SSH creds are needed to complete XML queries for missing data.
    I also suggest opening a support case so that they can enable additional logging and see if the AMON traffic contains the messages for translating the ports to common names.
  • 5.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 03:33 PM
    Any update to this? I just deployed a fresh build of 8.0.5 at a customer site and am seeing the same behavior.
  • 6.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 03:37 PM
    i have collected a plethora of log files and traces for the support engineers to take a look at.  So far i have validated the tellnet/ssh credentials and  dns settings.
    the case has been escalated.
    no solution has been found as of yet
  • 7.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 03:38 PM
    willy31 thanks for the update. I have also validated AMON, credentials, and DNS. Keep us posted. Thanks!
  • 8.  RE: Aruba Airwave AppRF
    sorry i forgot to include version info
    airwave 8.0.4.1
    aruba os 6.3.1.8
  • 9.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 03:40 PM
    I'm AOS 6.3.1.8 and AirWave 8.0.5.
  • 10.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 09:29 PM
    I'm seeing the same thing on a brand new deployment as well!
    AOS 6.3.1.9, all AP-225's, AirWave 8.0.5
  • 11.  RE: Aruba Airwave AppRF
    Posted Nov 20, 2014 11:15 PM
    Thanks all for the updates.  I will have someone in QA take a look at this and update.
  • 12.  RE: Aruba Airwave AppRF
    Posted Nov 26, 2014 04:44 AM
    Luckyvvt,
    We just tried this in our lab but we get full AppRF data in AirWave and the port to application translation works without a problem. Assuming the entier configuration is done correctly on the controller and AirWave, I'd suggest you open a support case so that Engineering can take a look at your setup and debug in detail. Thank you!
  • 13.  RE: Aruba Airwave AppRF
    Posted May 14, 2018 04:57 PM
    Hi, I have the same issue with an Airwave 8.5.2.1 and Controller 6.5.4.3. In all these years, someone found the solution?
    Thank you very much!
  • 14.  RE: Aruba Airwave AppRF
    Posted May 15, 2018 01:24 PM
    Hi ,
    Airwave recives port to application mapping using AMON feed , if airwave doesn't recive mapping for any port it will show as Port <port no> in AppRF charts
    Can you help with this information to check further ?
    1. Are you not seeing any applications in applications graph ? Are all coming as Port ?
    2. Are you seeing the applications in controller ? You can check using below command
    show dpi application all
     3 . Do you have root access to your system ? if yes , can you check content in pef_fw_application table , ap_pef_fw_application ?
    And it would be better if I can access your systen to check the issue further
    Sandeep Lade
    Airwave QA team
