Network Management
Aruba Airwave Ubiquiti
Hi, does Aruba AirWave support Ubiquiti equipement?
Aruba
Re: Aruba Airwave Ubiquiti
Airwave currrently supports:  Aruba, Cisco, HP and Motorola  WLAN devices.
There is a document within the online documentation of an Airwave server install that will give you more specifics.
JF
