Network Management
Aruba Controller monitoring with syslog
In our environment we have a veriety of hardware that we monitor (Aruba S2500s, HP 3810s, HP 2930s, and Aruba 72xx controllers.). We have implemented Observium with rsyslog integration, a free network monitoring solution, and things went rather smooth for our network swtiches, including the Aruba S2500s, but we are running into issues when adding the 72xx series controllers.
We have configured the controllers logging identical to our setup on the S2500 series switches, but it appears that syslog messages are either not being received correctly or the system is having issues interpriting the format of the message. Has anyone used this implementation before, or have some advice as to what may be the cause of this?
