Network Management
Occasional Contributor I
Aruba IAP 225 not connecting to Aruba Central
Hi Guys,
so i started a trial on Aruba Central. Did some searching about how to add devices and basically found it was done from Aruba Central itself.
Added two IAP 225 which are in a cluster and running InstantOS by using the MAC address and the serial number. AP's were added, i assigned them to a group and assigned licenses.
After that nothing really happens. I don't see the ap's connecting to Central somehow.
When i run the 'Show Ap Debug Cloud-Server' command i get:
IAP mgmt mode              :local-mgmt
cloud config recved        :FALSE
autojoin mode              :disable
state diff                 :disable
Device Cert status         :SUCCESS
When i run the 'Show Log Debug' command i get:
awc[3881]: isc_init: could not resolve ''
However i am able to ping from the ap.
Am i missing any configuration steps or did i do something wrong?
Would really like to see the possibilities of Aruba Central.
Thanks in advance.
Regards, Frank
Re: Aruba IAP 225 not connecting to Aruba Central
I ran into the same issue with some IAP-325's and found this article:
I SSH'd to the IAP and entered this command and it came up:  debug-cloud-server
I did a wr mem on it afterwards, but it seems like if the IAP gets rebooted it looses that setting and I have to put it back in...haven't had time to open a TAC case yet.
