Network Management
Aruba Network Management Tools
Hi guys, pretty new to aruba coming from a cisco background. Have been managing a new deployment for the last 6 months, done my ACMA and will be taking my ACMP before the end of the year.
We've had some pretty poor support from the company that installed the network. We were promised a solution that could centrally manage the switch config. i.e. We need to push configs out to all deployed switches (around 30 x 2930M)
What is the best tool for this? We were originally told OneView had this capability, however after deploying it today for our synergy's I see very little switch management in there. Is this possible through Airwave or Aruba Central instead?
All feedback welcome, apologies if posted in wrong topic. TIA
Re: Aruba Network Management Tools
You can use AirWave , Central or IMC (you can more features from IMC to manage the switches )
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
You can use Airwave to Push configs out to all the deployed switches.
Attached the URL which will point to Airwave Switch Configuration Guide.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28951
Please refer Chapter 4 (HPE Aruba Switch Configuration) for more information about Switch Configuration.
Hope this will help your query.
Madankumar
