Network Management
Frequent Contributor I
Aruba Switches Airwave
Hi!
I´ve got a question regarding Aruba switches (former procurve) and airwave.
I know that I can bring them in to Airwave with SNMP / SSH.
But can I make them connect to a airwave in a similar regard to Instant over internet ? I´ve got a couple of switches where I don´t have a ipsec tunnel between the sites and my airwave server.
The switches I´m working with in this case is Aruba2530-24/48G
Is this implemented in a new firmware maybe ? Coming up ?
It would be a great feature.
/Daniel
ACMP | ACCP | HP ATP - FlexNetwork Solutions
Re: Aruba Switches Airwave
This is what one of my colleagues has to say about this:
"We support IPSEC tunnel esp for Airwave from 16.02 Firmware.  But our support is limited to TPM devices.
     2530 YA / YB switches currently don’t have support to establish IPSEC tunnel with Aruba Mobility Controller."
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Alright, doesn´t anwer my question though.
My question was regarding airwave communication between switches and amp-server. And if this is possible to setup in the same regard as with IAP-clusters where I point out a public IP of the amp-server and the devices then communicate with amp by https over the internet. Or if I´m required to have contact with the switches on a routed inside network (snmp).
Sorry for any confusion.
/Daniel
Understood.  Asking.
Unfortunately, those switches cannot initiate traffic across a NAT boundary like Aruba Instant APs to Airwave.  They would need to be polled via SNMP from Airwave over a routed network.
ok, thank you for the answer.
Do you know if there is any plans for this feature ? Or maybe it isnt possible...
/Daniel
is it possible to import and manage aruba switches through a classic (e.g. IPSec) Site-to-Site VPN over public internet? if so, is there any consideration what the communication affect - like MTU size, etc.?!
