Network Management
ArubaOS 8 - How to remove down controller with cluster HA
ArubaOS 8 - I created the HA cluster with two virtual controllers, but one stopped working. How to remove the controllers down ???
Contributor I
Re: ArubaOS 8 - How to remove down controller with cluster HA
In the AOS8 CLI reference guide it says
clear master-local-entry <ip>
Not sure if that still works, but worth a try? It used to work in 6.x
Not work.
