Network Management
Contributor I
Ask for documentation (IAP with IMC)
Hi all,
I would like to test the management with IMC on IAP. But i can't find any documentation or topic speaking about.
Is there any one having such docs ?
Thx
Re: Ask for documentation (IAP with IMC)
AFAIK, IMC cannot manage IMC.  Only Airwave...
Contributor I
Ok, thx :)
When you say manage, do u also speak about supervise ?
I believe for now you can add an IAP as a generic device to monitor it, but not "Control or write configuration to it" .  Let me check...
http://community.hpe.com/t5/IMC/Aruba-Wireless-devices-aren-t-recognized-by-WSM/td-p/6748146
Hi Guys,
IAP's should now be managed and monitored ( SNMP only, no AMON ) through the latest patch of WSM. You should also get the E0403P06 patch for base platform as well which does add some device model definitions to help properly discover the IAP's through their SNMP assigned SysObjectID.
@netmanchris
