Network Management
Auto Acknowledge doesnt seems to work with down devices just when the device comes up
Hello
Im configuring an airwave and i got 2 simple rules
one that notify me when the devices comes up and it has the Auto Acknowledge for down and up
The other rule when a devices goes down (this rule does not let me to put the Auto Acknowledge (but i was thinking that the other rule would do it as it would give me option for up and down devices.
In this second rule i got when an access point is down send me and email
When its down for 5 minutes.
i got supress until Acknowledge in both rules.   As i dont want it to flood the email
What i want to actually achive is this
If the AP goes down, send one email.
If the ap goes up send one email
For example if i got a rap
I disconnect it i get the email
i reconned it i get the email
I disconnect it again and i dont get the email again... (as is not Auto Acknowledging)
If i reconnnecte it i get the email( because its Auto Acknowledging)
How can i achive what i need???
Cheers
Carlos
Alternetworks Corp
Moderator
Re: Auto Acknowledge doesnt seems to work with down devices just when the device comes up
The auto-ack feature will be going away in 8.1/8.2 (DE23208).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Okay
So how can i achive this rob? without manually ackowledging? or is the only way?
I disconnect it again and i dont get the email again... unless i ackwoledge manually
If i reconnnecte it  ill not get the email.  unless i ackwoledge manually
Alternetworks Corp
Moderator
Correction: Auto-ack for up/down alerts should still be available (there was a different auto-ack that was removed).  Let me try to replay your scenario to verify the behavior.
Rob Gin
you scared me when you said auto-ack is going away.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Trusted Contributor I
did you get this worked out Rob?
