Network Management
BPDU Guard alert airwave
Is there a way to send a email alert or anything like that or that you can see it on airwave somewhere when the switch bpdu guard see a switch connecting to a port fast and disable the port cause of the bpdu guard.
Cheers
Carlos
Alternetworks Corp
Moderator
Re: BPDU Guard alert airwave
There's no specific alert designed for that yet.  Do you know if the switch sends any sort of snmp trap when that event happens?  If so, you might be able to try to use the device event alert triggered by the snmp trap.  Otherwise it's a feature request.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Its an aruba os swithc... ill ask on that forum to see if someone knows
Cheers
Carlos
Alternetworks Corp
