Network Management
Block a specific URL
Hi
I wish to restrict access to a specific URL on the Aruba Controller for all users?
Frequent Contributor II
Re: Block a specific URL
hi,
steps you'll need to do is: create a destination with that specific url, add a rule in global acl with that destination blocked.
Creating the destination:
Configuration > Advanced Services > Stateful firewall > destination
create a destination with type name (I think)
Rule should just be: any alias "destination-you-just-made" any drop
Something like that ;)
It actually is for pokemongo. What I am seeing if the respective URL's are pgorelease.nianticlabs.com
yeah, you can block that url with an ACL. Just like in the instructions, create a destination with that url and add a rule blocking that destination. Simple as that. Blocking it for everyone should be easy by adding it to the global ACL (is applied to every user role).
Thanks. Can you expand on the ACL.
We also have virtual controllers, how would it done at that level?
Can't really get to screenshots at the moment but can give you the cli code:
netdestination pokemongo
name pgorelease.nianticlabs.com
ip access-list session global-sacl
 any alias pokemongo any deny
That should be about it.
