Network Management
COMMAND TERMINAL MONITOR FOR ARUBAOS
This thread has been viewed 33 times
  • 1.  COMMAND TERMINAL MONITOR FOR ARUBAOS
    Posted May 02, 2018 11:22 AM
    I would like someone to help me with the Comware equivalent command: "terminal monitor" for arubaOS.
    Thank you.
  • 2.  RE: COMMAND TERMINAL MONITOR FOR ARUBAOS
    MVP EXPERT
    Posted May 02, 2018 11:29 AM
    It is show log, granted it is not a running view like term mon. You can also use pipe to filter results.
    (WLC-1) #show log ?
    all                     Show full logs
    ap-debug                AP Debug Logs
    arm                     ARM logs
    arm-user-debug          ARM User Debug Logs
    errorlog                Logging for System errors or critical information
    network                 Network logs
    security                Security logs
    system                  System logs
    user                    User logs
    user-debug              User Debug Logs
    wireless                Wireless logs
  • 3.  RE: COMMAND TERMINAL MONITOR FOR ARUBAOS
    Posted May 02, 2018 11:34 AM
    I see that your scenario is for a WLC, I will see if I can apply these same commands on an aruba switch.
    Thanks for the reply :)
  • 4.  RE: COMMAND TERMINAL MONITOR FOR ARUBAOS
    MVP EXPERT
    Posted May 02, 2018 11:37 AM
  • 5.  RE: COMMAND TERMINAL MONITOR FOR ARUBAOS
    Posted May 02, 2018 09:08 PM
    debug destination session ?
    #AirheadsMobile
  • 6.  RE: COMMAND TERMINAL MONITOR FOR ARUBAOS
    #AirheadsMobile
