Network Management
Re: Can I monitor wired RAP users with AirWave?
There's a known issue similar to this problem in the release notes of 8.2.3.1
Symptom: The bandwidth usage is not reported at the group-level for wired clients.
Scenario: The Groups > List page should report bandwidth usage for wired clients.
Workaround: There is no workaround.
I contacted our HPE PreSales to report and maybe get some more information when it's getting fixed.
We have a bug in Airwave related to RAP wired clients not showing in Aiwave DE22391 and this will be fixed in AMP 8.2.4 version. ETA of this release in end of march.
If my post helped you ? Give Kudos :)
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
