Network Management
Can I use Airwave to deploy a Cisco 5508 Controller in a remote location?
I would like to use Airwave to deploy a new Cisco 5508 Wireless LAN Controller in a remote office. Are there any guides or instructions for new device deployment that would cover the 5508?  Thank you in advance for any help.
Re: Can I use Airwave to deploy a Cisco 5508 Controller in a remote location?
I have attached the Airwave User guide for version 7.7.x
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you Victor!
